I am trying to capture footage on my new Sony PC-105e with a 1394 f/wire card yet keep dropping many frames,This never happened on my older PC-5e,But maybe I've got too much on my hard drive or something (7 Gig used)on a 30 gig,I'm stuck on this one,Even having put a spare 30 gig on but get a "sorry cannot capture, The data rate on drive D is less than the require 4444 k/bytes a second" Any ideas guys??PLEASE.....
try defragmenting your HDD
Guns don't kill people, people kill people, guns just make it a lot easier. -
Thanks for that mate DMA wasn't enabled but the frames are still dropping,So I'm gonna disable Go-back etc,And persevere!.
Definitely read Tx's frame dropping thread -- it's quite good.
My gut reaction is there is something wrong in your OS -- with WDM enabled there shouldn't be any frame dropping in a modern setup. Are you running XP? I would strongly recommend it (although Win2K is a decent substitute). If not, that's probably your problem right there.
And is your second hard drive spinning at 7200? If it is not, pick up a (cheap) video drive: for less than $100 you can buy 120GB of 7200 hard drive storage. No excuse not to have that.
All that said, Sony computers do indeed have some funky issues with video -- as I recall, they build in all this stuff (your firewire is resident on the motherboard, right?) and more than one person has complained about it not working right. Your ultimate solution might involve dropping back to your old computer."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 11:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
System dropping frames because it's getting old?
By quanz in forum Capturing and VCRReplies: 16Last Post: 30th Nov 2009, 06:20 -
WinDV dropping frames
By 2Bdecided in forum Capturing and VCRReplies: 3Last Post: 17th Oct 2009, 03:23 -
New Computer Dropping Frames
By bthig in forum Capturing and VCRReplies: 20Last Post: 14th Jul 2008, 15:06
