How do I extract the Audio only from a MPEG1 file? Its VCD format with audio 224Kbs. I want to use the Audio in a different video.
I have Ulead VS7 and TMPGenc.
One way is to go in to TMPGEnc, go to the File menu, go to MPEG Tools, click on the Simple De-Multiplex, add your .mpg file, then click Run. That will then give you a .m2v file (your video) and a .mp2 file (your audio).
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
You can save .mp2 audio in VS as well by using "Create Sound File" but TMPGEnc is faster.
Just load your VCD file into TMPG and go to FILE > OUTPUT TO WAVE and this will save a wave version of the audio for you to convert to whatever other format you need.
Extract audio from MP4
By aiyoyo in forum Video ConversionReplies: 5Last Post: 12th Dec 2013, 16:35 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 24th Jan 2011, 00:28 -
How to extract audio from a VCD?
By c1steady in forum AudioReplies: 2Last Post: 14th Jan 2010, 21:16 -
looking for software that will extract hardcoded subtitles from mpeg1
By jimdagys in forum SubtitleReplies: 2Last Post: 3rd May 2009, 10:10 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 20:00
