I recently bought a DV camcorder that renders wonderful recordings. When I hook it up to a TV, the images look great. When I use my firewire connection, I can easily record it to my hard drive as an .avi file and it, too, looks crisp.
Now here's the rub. I want to put the finished product on a DVD, but encoding .avi to DVD takes forever and, the worst part, I lose considerable image quality and contrast.
I have Adobe Premiere 6.02 and don't know if upgrading to 6.5 (or 7.0) is worth the money. I've also used Ulead's Movie Factory.
As I understand it, .avi files take up a lot of space -- like 20 minutes to a DVD. QUESTION: Since I'm new to this, is there a better way? Also, how much better is DV quality than Hi-8?
Thanks!
Confederate
"If at first you don't secede, try, try again!"
Try using tmpgenc 2.55 for encoding DV to DVD and you will find there will be no loss in quality. I have been capturing analog video using Canopus ADVC 50 and saving in DV, then encoding it to VCDs which I find is quite good in quality.
vsenapati -
Yes the upgrade to Premiere 6.5 is worth it. It comes with Main Concept encoder, wich is excellent ( make sure to update to v1.3, it's 30% faster). I don't know what you used for encoding, but either you used wrong settings or the encoder is garbage. I use CBR @ 8000 kbps and it looks as good as source DV.
From what i've read, Mini DV has over 500 lines of horizontal resolution. High 8 has 400 lines only if viewed using S-Video.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
Getting decent quality in a single layer...
By AdamJosiah in forum Authoring (DVD)Replies: 1Last Post: 2nd Apr 2010, 21:43 -
decent vcr replacement
By yuhr in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2009, 13:06 -
Is this a decent/value custom build?
By Killer3737 in forum ComputerReplies: 1Last Post: 8th Jul 2009, 09:22 -
Looking For A Decent Camcorder Under 200$
By DJboutit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th May 2009, 12:13 -
A decent free DVD\CD author
By GimpGuy2000 in forum Newbie / General discussionsReplies: 17Last Post: 30th Jun 2007, 14:49
