Just got an NEC1100A for $139. I also use Sonic Mydvd ver4 along with Arcsoft Showbiz. Not a bad software to do basic authoring. However, once I was finished editing my video from my DV camcoder, I burned the final project with Mydvd using TDK +R media. It would not work on my APEX 1200 dvd player - "not recognized".. I tried another brand of +R media and would not work. Finally tried it on a Sony +RW media and it worked fine..Whats up with that? Why cant I use cheaper +R media ?
Are you running the latest firmware? I think it's 10GE or something like that.
Anyway, I've used the 1100A with MyDVD and the +r's have worked fine with Verbatim, Maxell and Imation. FYI only -
Compatibility largely depends on which media you use. I use my NEC1100A burner to burn on FUJI +R/+RW dvds that only work in Sony DVD Players -- which is the only kind of standalone player I have.
<-------- read more about your specific DVD player and media compatibility using the "DVD Players" link over here
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 02:47 -
ArcSoft Showbiz DVD 2 Smart Rendering
By zulubase in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2009, 22:12 -
Transitions make static in Arcsoft Showbiz MPEG2
By Canopus Smoker in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2008, 23:10 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 20:48 -
ArcSoft ShowBiz Audio Problem
By KenOBrien in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2007, 07:29
