  1. I hav'nt used TMPGENC for a while and have got a new DVD i want to back up to disc. I have used smart ripper to extract vob files, and used DVD2AVI to capture the audio as wav and video as dv file.
    However unlike before when on the project wizard for TMPGENC selecting the movie d2v file it states it isnt recognised or unsuported.
    Why is this Im sure i did it this way before to encode to Mpeg.
  2. Go into TMPGEnc > Options > Environmental Settings > VFAPI Plugin > Do you have DVD2AVI Project File Listed?
    Is it high priority (1)?
    "Today is only yesterdays tomorrow"
  3. ive looked at that , listed there is and all ticked ;
    Avi(openDML)file reader
    BMP/PPM/JGH/JPG
    Microsoft -Mpeg Decoder
    wavFile reader
    TMPGENC Product file
    Direct Show
    AVI View Compatability.
    Still not working?????
    If there's another programe ( software ) that will do this bit ie the bit between vob to TMPGenc and easy to sort let me know ill use that instead.
    I have used Smart ripper
    DVD2AVI
    TMPGenc
    VCDeasy
  4. If you have this version of DVD2AVI(with vfapi)
    http://www.divx-digest.com/software/dvd2avi.html
    Then by simply opening DVD2AVI , it will register the .dll and you should then see...DVD2AVI.vfp in the TMPGE list.
    Then it will work for you.
  5. Thanks alot will try and update if it works tomorow.
  6. you have more than 1 version of dvd2avi installed??
  7. Thanks , i ve sussed it out , it wasn't a tmpgec problem , i messed up on the original rip. its sorted now and on my disc ............ many thanks.
