I recently purchased the panasonic hr2. i thought i could record dvdram to Hdd but that did not work. my question, do i need to purchase another dvd player to make copies of my dvds.
To record dvd's to your hs2 you will need another dvd player. If the dvd's you have are copyguarded, you will need a dvd player that has macrovision/cgms removed or a filter box box hooked up between them that removes the cgms.
The HS2 allows you to dub from -RAM to the HDD and vice versa. However, you can't dub from -R to the HDD. Are you sure you used -RAM disc? Maybe you used -R disc instead..
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 14:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 12:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 22:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 15:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 02:12
