I have the 3 Pioneer DVDR 105 and some come with BIOS 1.00, 1.1 and 1.2 or something. Do I need to update the BIOS of these Drives to 1.31 or 1.33 [not sure which one is current] to be able to write at 4X and so far with the exisiting DVDRs I have tried on most DVDRs I CANNOT Write a 4x and lucky to get at 2x ... I got all DVDRs from MeritLine and worst is all outmedia.. theirs I got.. I was able to burn but cannot be read back on any DVD ROMS and only the burner that burned the DVD was fine.
Most current firmware version of Pioneer 105/A05 is 1.33, but I'm not sure that's your problem. I've used 1.30 with great success. Check your media, if 4X and good quality, then there maybe something wrong with your procedure. I use BeAll media from Meritline and RecordNow Max to burn. Works flawlessly.
Go to www.Rima.com or www.meritline.com, click dvd-r, scroll down to the 4x sample pack. Buy that, burn some movies, test it out, then buy in bulk whichever disc worked the best for you. Also make sure you author the disc correctly.
Meritline TY Final Sale
By terryj in forum MediaReplies: 2Last Post: 21st May 2008, 12:37 -
The east coast gets a major media vendor: Meritline adds a warehouse in MA
By Bix in forum MediaReplies: 4Last Post: 15th May 2008, 15:23 -
Looking for DVD player replacement - Good DVDR media support? (~£50)
By John_Jordan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Mar 2008, 15:12 -
Meritline - still in business?
By CBC in forum Off topicReplies: 3Last Post: 5th Dec 2007, 09:23 -
Samsung DVD+R 8x $5 per 25 at Meritline
By bevills1 in forum MediaReplies: 2Last Post: 16th Jun 2007, 17:56
