Hi, for some reason, when I use the wizard and load the video file, before it usually loaded the audio along with it, and now today when I load the video it only loads the video. And when I try browsing for the audio and select the source that it should come from (the video) it says its not supported? Is there some settings that I might have accdiently pressed that makes it not load both at the same time? Thanks!
Results 1 to 15 of 15
Check what format the audio is in. Tmpg doesn't support some formats like .ac3.
You can check your file with Gspot (in the Tools section) to see if you have the required codecs installed, if not then get them.
It's usually recommended to extract a wav file and use that as your audio source when you encode. I prefer Goldwave, here's a guide."Art is making something out of nothing and selling it." - Frank Zappa -
oh wow thanks for the advice guys! i think the problem is the prgoram too though cuz I tried encoding things I have encoded before that worked fine.......so if I extract the audio to wav, i just load the wav into the blank of tmpgenc? and continue like normal? Thanks !
Originally Posted by oOGoldenSunOo
BTW, do you use Toolame as an external audio encoder for TMPGEnc? It's better quality (from what I read) and is available in the Tools section as well. You enable it under Options>environmental settings>external tool>layer 2 encoder."Art is making something out of nothing and selling it." - Frank Zappa -
just a question, will file size be better if you covert to wav? cuz I liked the file size the result mpeg was when my tmpgenc actually worked....
It doesn't matter what format audio you use, as long as you convert it with the same settings, the file should be the same size.
Originally Posted by oOGoldenSunOo"Art is making something out of nothing and selling it." - Frank Zappa
Convert your audio to a wav file tmpgenc will not use ac 3. use dvd2avi its on the forum guide
ok, sorry for asking so many questions, but I made a seperate wav file and then used TMPGENC to encode a video using the wav file as the audio source, and then when I played the resulting mpeg video, the video had no audio? what's up with that? thanks...
That seems strange , did you play it / checkit first before using it, check its there with windows media player . if it was there and didn't work ?
yep I played it and i can hear the audio, do you think somethings wrong with the audio in my tmpgenc program? cuz I tried reinstalling it and for some reason it does the same thing....is there a way to COMPLETELY unistall it... thanks
oh yeah another question, since i have multiple files to encode, is there a way to make sorta a "playlist" type thing for tmpgenc? so I can leave it on over night and i can just preset the settings I want and let it encode each video? cuz that would be more efficient thanks!
Im not an expert though if u wanna get rid of it to reinstall , do a search from your start menu for files folders including hidden ones , delete the lot then install your new program.
you can do more that one with tmpgenc by using the project wizard, on the last page it says encode now or create another project for encoding. if u tick that it takes you back to the start to line up another one.
however in my experiance if you do loads theres always one in the middle which messes up.
hope that helped , if not im sure there will be other replies. -
Yeah, use the batch encode function. You can also save the individual projects and reload them for later encoding if one of them fails.
Problems loading...
By alintatoc in forum ComputerReplies: 2Last Post: 9th Dec 2010, 01:49 -
SOLVED : Problems loading certain .srt subtitles
By trotskyicepick in forum SubtitleReplies: 1Last Post: 13th Sep 2010, 11:00 -
losing audio when loading into vid editor..
By krohm in forum EditingReplies: 26Last Post: 24th May 2010, 08:41 -
problems loading flv vids into avidemux
By tryvora in forum Video ConversionReplies: 5Last Post: 29th Dec 2008, 16:36 -
Problem loading AC-3 audio (inside MPEG) in Premiere
By irving in forum EditingReplies: 2Last Post: 23rd May 2007, 09:25
