That only applies to VCDs because they use a specified constant bitrate. When it comes to SVCDs, you just have to go by the filesize and like Sefy said, an 80 min cdr can hold about 800MB's worth of data. When you make a SVCD the first thing you should do is decide how many cds you want to use and then set your bitrate so that you can match this size. You can do this using a bitrate calculator or if you are using DVD2SVCD it basically does this for you. You typically want to shoot for between 50-55 mins per disk and I don't recommend ever going over 65 mins per disk.
Results 31 to 42 of 42
Thanks everyone who helped me especially Sefy, I have just produced my first DVD rip and it looks great. It took about four days to encode but well worth it, the only thing I don't have are the extra features but that is okay, and the best thing is that the movie fits on one cd.
Great, thanks again. -
Four Days To Encode ?
What Chip you got in there ? a Dorito ?
Always Glad to be of Help!Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Which Windows do you have ? 98SE and above can tell you the CPU type and some can tell you the speed as well, just right click on "My Computer" and select Properties, it should be in the main screen.
AMD: K6-2 / Duron / Athlon / Athlon XP / Athlon MP
Intel: Pentium / Pentium II / Pentium III / Pentium 4 / Celeron
I'm guessing your CPU is one of those aboveEmail me for faster replies!
Best Regards,
Sefy Levy,
It is a Pentium [R] 4CPU 1.70 ghz. Should the encoding be that slow. When I encode an avi. file it doesn't take that long.
Most Defenetly Should Not Take That Long
Best Regards,
Sefy Levy,
That's what I thought, do you have any explanation why it might have taken so long?
Was TMGPEnc the only active application at the time of encoding ? it is CPU intensive, so if anything else was working it could have taken CPU time from it.
Best Regards,
Sefy Levy,
Occasionally I was doing things on the internet but that was it and it wasn't the whole time.
Which version of TMPGEnc were you using ? and which Template as well ?
Best Regards,
Sefy Levy,
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 09:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
