Results 1 to 16 of 16
  1. When I try to create a menu I get error message "unhandled exception", details pasted to end of this message. This occurs as soon as I click the menu option on the author box. The menu folders are definetly in the correct location.
    Ive tried reinstalling with latest build downloaded off website, currently Im running;
    SVCD2DVDMPG+ Build 1.0.1271.35733
    GNU VCDImager v0.7.12
    MJPEG Tools v1.6.0-rc2
    Mpegtx v1.3
    Magic Library v1.7.3
    Any help appreciated.
    Error Message:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentException: Invalid parameter used.
    at System.Drawing.Bitmap..ctor(String filename)
    at d.g(Object A_0, EventArgs A_1)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVDMPG+
    Assembly Version: 1.0.1271.35733
    Win32 Version: 1.0.1271.35733
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVDMPG+/SVCD2DVDMPG+.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    RegistrationSDK
    Assembly Version: 1.0.1218.19534
    Win32 Version: 1.0.1218.19534
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVDMPG+/RegistrationSDK.DLL
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    System.Security
    CodeBase: file:///c:/windows/assembly/gac/system.security/1.0.5000.0__b03f5f7f11d50a3a/system.security.dll
    igoumsqp
    Assembly Version: 0.0.0.0
    Xceed.FileSystem
    Assembly Version: 1.0.29.0
    Win32 Version: 1.0.29.0
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVDMPG+/Xceed.FileSystem.DLL
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    MagicLibrary
    Assembly Version: 1.7.4.0
    Win32 Version: 1.7.4.0
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVDMPG+/MagicLibrary.DLL
    FolderBrowser
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVDMPG+/FolderBrowser.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  2. i got the same problem when i tried to use them, haven't figured out what the problem is but it has something to do with dot.net
  3. Daza
    Guest
    I also had this problem
    Resolved it by the following method -- When I downloaded the Menu's
    the folder was called: menus
    Inside this folder was another folder called: menus
    You need to put the folders that are inside that into the 1st folder
    Ie: you must only have 1 folder called: menus
    Then the folders inside them will be: Badger #1, Badger #2
  4. i have the menus in the right place but still have this problem
  5. GrayW
    Guest
    Getting the exact same problem as MaSo.
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    There is an update now which improves the chances of menus working. That error though is typical of not locating the bmp file.
    This is the correct folder topography:
    [/i]
  7. GrayW
    Guest
    Thanks for your help, but I have done update and checked folder and still it fails.
    Anybody else got this to work after this error?
  8. Guest
    no.
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Wanna email me? I'll try to get to the bottom of this.
  10. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok, thanks to Graham C's testing I've managed to resolve this issue.
    I believe you are adding a new VTS to make a total of two but not adding any mpgs to the second VTS. The second VTS is therefore not valid & so is ignored. In the new build (1.0.1295.36423) you are forced to add an mpeg to the second VTS to enable the menu button.
    Anyway update as usual. There is also a fix to the fact that the menu.mpg file is created "read only" which means that a second menu has issues...... Roll on DVD Menu Maker..... (its like win2k Vs ZX81 )
  11. Your welcome Chris and once again a very big thanks for taking so much time to pinpoint the problem I was having.
    I can say only again, that I hope 1000's donate for a copy of Svcd2dvdmpg+ and give you back some reward towards the time you spend on this project.
    It really is a class program and the support is also first class!
    All the best
    Graham
  12. dd
    Guest
    great program.
    having the same minor prooblem with menus. is there a fix for dummies like me ? I tried to follow the suggestions without success.
  13. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    dd: whats the problem?
  14. DeMoNPauL
    Guest
    I had this same problem with 1.5
    At first it stumped me but when i looked at it it was looking on drive c:
    and as i have the program installed on d: i then realised the problem was here.
    Easy solution is to copy the whole badgersoft dir to the c: drive in the program files dir or reinstall svcd2dvd onto your c: drive or the drive containing your os.
    well hope this helps as it did for me
  15. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    yep until i get round to fixing the installer you must install in the default location.....
  16. dd-
    Guest
    thanks guys. fixed it today. I went into the svcd2dvd directory and double clicked on DVDMenuMaker application. It opened up, I then closed out of the application and opened svcd2dvd. everything worked fine.... thanks again.
