I wanna capture some old vhs tapes
but when i capture 7 min the file is almost as big as a movie .
size 731.377.664
I'm using Wintv 2000
Output i want to have is Avi
Compressing codec i use divx 5.0.5
who can help me out![]()
Sounds like you are capturing into DV format. The numbers are about right. I am not familiar with WinTV, can it encode while it captures?
If so, re-check your settings and make sure it is applying the codec correctly.Just what is this reality thing anyway? -
you are capturing with the wrong codec.
capturing direct to divx is very processor intensive. since you have already captured the file, open it in VirtualDub, select Full Processing under Video, and Divx 5 under compression codec, and reencode the file.
or figure out where you can change the codec you are capturing with in your capture app, and change it. it sounds like it is defaulting to a DV codec.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Banks are so freaking greedy
By stiltman in forum Off topicReplies: 12Last Post: 17th Oct 2011, 07:58 -
Min DV capture, with auto scene file splitting on the fly
By Hitmandj in forum Capturing and VCRReplies: 2Last Post: 15th Jun 2011, 17:40 -
10 min max file for YouTube
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2010, 07:59 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40
