I have been trying to use instant copy to shrink movie files that I have already stripped with dvd shrink but no matter what I set the slider to it will always come up with the same output. For instance, with catch me if you can, whether I set the output to 50% or 90% I end up with a 2.5 gig movie? Can anyoone help me with this?
Generally IC is used on non compressed data. I have used it with Shrink, using crop/edit features and stripping audio files, but have always left it at 0 compression.
IC does sorta of "hit a wall" at times and won't go larger.
If you still have the disk/decrypted files, rerun shink without compression. -
I only used dvd shrink to get the main movie only and strip audio and subtitle tracks. The video was done at zero compression. And it is not just that it won't get any bigger because I did the same thing with Beautiful Mind and I can't get the thing below 4.55 gigs no matter what I set it at. Thanks for the reply though.
it must be the 2:35:1 widescreen ratio as ic7 has problems with these
it call the black bar issue
https://www.videohelp.com/forum/viewtopic.php?t=165261&start=0&postdays=0&postorder=asc&highlight=
store bought dvd won't play in laptop or pc, can't copy
By ghola in forum DVD RippingReplies: 11Last Post: 8th Mar 2012, 16:17 -
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 09:42 -
DVD player's copy protection won't even let me rip home movies.
By Brian. in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th Mar 2011, 15:12 -
DVDFab 6 won't copy all files...
By takearushfan in forum DVD RippingReplies: 4Last Post: 20th Dec 2009, 13:49 -
xvid-AVIs won't play until re-saved in "copy"-mode
By Information in forum Video ConversionReplies: 0Last Post: 5th Dec 2009, 09:03
