If i have 2 files in my video_ts folder with exact same size ,lets say 5,283 gb , how do i know wich one is the main movie file ,is it always the one who is first of these????![]()
well, at first glance, it would appear that they are both the main movie files, but a little more info is needed...
How did the files get there, i.e., did you rip them using Decrypter or SmartRipper? and what type files are they, ie., .VOB, .m2v, etc.. ? -
I just open the original dvd with dvd shrink and there are 2 with exact size !Not used any decryptor yet!
take a note which vob sets you're confused about...
then, play those vobs directly with powerDVD/winDVD....the audio, aspect ratio may be a little bit off, but you should be able to tell which is the main movie and which is the extra, after you watch them...
btw, does your DVD have both widescreen and full screen versions of the film on the same side of the DVD???
How do I get the exact file size I want with Virtual Dub ?
By Simmons in forum Video ConversionReplies: 3Last Post: 21st Jul 2011, 02:32 -
exact copy with more than 2 folders ?
By takenotes in forum MacReplies: 3Last Post: 27th Oct 2010, 21:19 -
MP4/h264 Exact File Size Encoding
By Trismegistus in forum Video ConversionReplies: 1Last Post: 23rd May 2010, 09:57 -
How do I get exact durations?
By bratpop in forum DVD RippingReplies: 7Last Post: 19th Nov 2008, 15:08 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40
