Hi all,
Assuming that you have a "perfect" capture card which has an audio lock feature and your Audio and video are always in sync using the capture card by itself, can using a TBC (more specifically TBC-1000) cause any A/V sync problem? As far as I know, a TBC would digitalize the anolog signal in order to re-condition the signal and then convert it back to anolog once again. So, If I use a TBC between my VCR and capture card, is it possible that the TBC would cause sync A/V problem?
Thanks.
Any product similar to the AV Toolbox AP-411 lip-sync corrector?
By svejkovat in forum AudioReplies: 3Last Post: 5th Feb 2012, 13:29 -
What does a time based corrector actually correct?
By Rudyard in forum Capturing and VCRReplies: 15Last Post: 26th May 2010, 07:45 -
Time Base Corrector Information
By Sprout in forum Video ConversionReplies: 4Last Post: 11th Apr 2010, 04:33 -
Do I need a Time Base Corrector? If so, which do I get?
By Smack2k in forum Capturing and VCRReplies: 3Last Post: 11th Jul 2008, 11:41 -
Anyone try the TV One 1T-TBC time base corrector yet?
By heman31 in forum RestorationReplies: 0Last Post: 15th Sep 2007, 18:20
