I have re encoded an mpeg 2 file to mpeg 1 using tempeg.But i get this anoying box that floats around the screen when played back on my pc and on my stand alone dvd player (that wont play mpeg 2 files.)
any ideas/sugestions(apart from buy a new dvd player)
cheers
B.![]()
Originally Posted by mabos22
The cube shape that flickers around the screen is white made up of 9 smaller cubes.
It is svcd format that wont play on my dvd player, but normal vcd's play fine.
Ahhh. now I see. This has just been covered in another thread too. It is because you have the Elecard mpeg-2 codec, Demo version installed. This is what generates those cubes, its a sort of watermark. Either buy the full version, or un-install it and then download and install either power DVD or Win-DVD. Demo versions should be OK. They will install a new mpeg-2 codec for you that doesn't have those annoying sqaures.
Hope this helps. -
Thanks for the quick reply. I will follow your advice straight away.
And maybee i'll be able to put my fly swater away.
Big thanks.
Encode YouTube video to MPEG-2
By RL in forum ffmpegX general discussionReplies: 4Last Post: 31st Jan 2011, 23:31 -
MPEG Streamclip Encode Wrong
By joaovitor in forum Portable VideoReplies: 1Last Post: 20th Jul 2010, 14:03 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 19:08 -
National Treasure 2 will not encode to MPEG
By shoeshine in forum DVD RippingReplies: 1Last Post: 10th May 2008, 10:52
