I used few different analogue capture cards and my expirence says the best is the cheapest: Manli TV card with Philips SAA7130. On second place is Ati Radeon 9000 VIVO (Theater chip), follows ASUS 7700 with VIVO and the last one is Pixelview TV Pak (BT848 chip). As base for comparision I used only video capture quality (without tuner performance etc). SAA7130 gives the best capture quality and average VHS tape gives (after preprocessing and filtering, of coarse) better picture than ATI captured file. With strong VCD template in TMPGENC ( "very slow") appropriate VCD is even better as original VHS (decreased picture noise, audio cleaned, normalized, filtered etc.) The only disvantage is incompatibility with virtual dub (known WDM / VFW problem), but there are a few another compatible programs (ATV, VirtualVCR etc.).
ATI has captured frame with small thin horizontal lines carefully visible on full screen resolution, I compared it directly with SAA7130 captured file produced with the same video sequence and identicall codec huffy. Final product (MPG2/1) doesn't have this lines but noise level in video is a bit bigger than MPEG2/1 based on SAA7130 capture.
Last two card are in second row because of lack of XP/2K support and much worse capturing.
My last impression is that two first analoge capture cards give better final product than one based on VHS -> DV passthru methode.
Please your opinion about my comparison and tests.
Results 1 to 1 of 1
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
