witch player should i use to play dat.files?
i realy need to check that i`m downloading the right movie clip
do i need any codecs?
Pee
oh dear you are new
simple media player
open the folder where your .dat file is then select view all files it should show up
https://www.videohelp.com/play -
windows media player says unknown format. the dat.file have notepad icon on it.
Pee -
Not all DAT-files are VCD files (or lets say, most are not VCD files), so be sure you open the correct file, for example from the MPEGAV folder on a VCD. You could also try to play it with your software DVD player, how to open is different in different players. With PowerDVD you just press CTRL O and then select the drive with the VCD disk in it, or to open a DAT file, you select "Open mediafiles" (still after pressing CTRL O).
For the "very newbies", like you, it would help to read some of the guides and articles here. Good luck! =) -
Check out AVI Preview. I think it is what you are looking for.
http://www.avipreview.com/"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 09:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 22:27 -
AVSEQ.DAT file -video cd can't copy and play
By desiboy1436 in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th Jul 2008, 11:43 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 08:03
