I have Macromedia Flash movie files in *.SWF format.
How can I convert them to *.AVI?
I tried importing the file into Macromedia Flash and then exporting as AVI but what I get is just a blank movie and no sound at all.
Any help is very much appreciated.
Screen Saver Discussion TOC (Framed)
... swf to .fla ( Flash ) Mxacker@yahoo.com 24 Apr 2003 Re: Who to convert .swf to .fla
( Flash ) maro, scooper_m@yahoo.com 02 Jan 2003 Converting .mov or .mpg to ...
www.th-soft.com/en_forum/disc_e_tocf.htm - 58k - Cached - Similar pages
Top: Software: Search for 'converting'
... Single mode for one-file conversion and Batch mode for converting several files. ... AVI,
Mpeg, Mpeg1, Mpeg2, Mpeg4, VCD, SVCD, DVD, DivX, ASF, and QuickTime MOV. ...
www.freewareseek.com/search.php3?q=converting - 36k - Cached - Similar pages
Top: Software: Search for 'Player MOV'
... Join Leave. Top: Software: Search for 'Player MOV'. ... Swift optimizer 1.0 Register Swift
Optimizer is the most powerful tool to optimize the swf files in windows . ...
www.imagespro.com/search.php3?q=Player+MOV - 37k - Cached - Similar pages
ImagesPro.com :: Most popular search queries in the last 24 hours
... video enhancer, 3, 0. converting mov files to avi, 3, 0. emf and eps, 3, 11.
avi viewer, 3, 48. edit asf, 3, 3. decompressor Vids:div3, 3, 3. swf converter,
3, 4. mp2v, 3, 0. ...
www.imagespro.com/queries.php3?p=5&s=1 - 17k - 8 Jul 2003 - Cached - Similar pages
[ More results from www.imagespro.com ]
Actionscript.org Macromedia Flash Resources and Tutorials
... It will convert AVI, MPG and MOV files into flash SWF.Use beta1 version ,it works
as a ... SwF convert is a program that makes converting images, sounds and ...
www.actionscript.org/software/converters_to_swf/ - 27k - Cached - Similar pages
AVI to MPEG converter - WinMPG Video Convert to convert AVI to ...
WinMPG Video Convert is a complete solution for video file converting. ... Support
QuickTime MOV MP4, Support Flash SWF. Download. Free trial download ! ...
Description: Software to convert AVI to MPEG, AVI to VCD,AVI to DVD. It supports almost all video file format,...
Category: Computers > Software > Shareware > Windows > Multimedia
www.winmpg.com/ - 7k - 8 Jul 2003 - Cached - Similar pages
Bill's Design Tips - Flash, Graphics, and much more
... if (movie_value==1) loadMovie ("agent01.swf", "mov");. else if (movie_value==2)
loadMovie ("reuse_movie.swf", "mov");. else if (movie_value ...
www.dcs.napier.ac.uk/~bill/design_tips65.htm - 16k - Cached - Similar pages
Swish-Tutorials Forums [Powered by IB Forums]
... however the best compression I've tested to date is exporting as mov then converting
with a streaming swf format such as swideo/flix [Edited on 24-7-2002 by ...
www.swish-tutorials.com/forum/show.php/ act/Print/client/printer/f/4/t/532 - 7k - Cached - Similar pages
Flash video encoder - Wildform Flix
... Free Flash 6 Player for previewing SWF files: http://www.flash.com; Free QuickTime
Player 5 (complete installation) for converting/previewing QT, MOV and DV ...
www.wildform.com/flix/requirements.php?sid= - 14k - Cached - Similar pages
V2F Video to Flash converter 1.0 free download by Crash Software ...
V2F is an EZ to use program for converting your .AVI, .MOV, .MPG, .MPEG digital
video to .SWF Flash format ready for the web or Ready to import into Flash ...
www.softpile.com/Multimedia/Video/ Review_08783_index.html - 18k - Cached - Similar pagesJUST EDIT & PLAY.................apnait.com -
What was that above? ..the complete results of this guys GOOGLE SEACH no doubt..
unfortutunaltely most of those links discuss putting movies into FLASH (the reverse of what you're doing) or are e-mail links..why?
well if you've done this before, the screen could be black because your system is missing the codec that FLASH wants to use..
A good thing is to try a differnt codec..the last window that pops up when you export to AVI is the key (in FLASH MX i'm talking)
Choose a codec you know exists on your system..The default is UNCOMPRESSED..Huge file size..but very good..However it seems this is the kind of file you made so try with a different codec like DIVX or Intel Indeo
from macromediahttp://www.macromedia.com/support/flash/how/expert/flashontv/Video Codecs - Although Flash MX fully supports QuickTime and AVI, you may experience issues with particular codecs.
Convert large SWF to AVI?
By tripflex in forum Video ConversionReplies: 10Last Post: 9th Apr 2010, 13:00 -
convert flv to swf or avi
By thecrock in forum Newbie / General discussionsReplies: 4Last Post: 1st Apr 2009, 16:33 -
What is way convert swf to WMV or AVI?
By siluet in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2009, 01:33 -
convert AVI to swf
By theewizard in forum Video ConversionReplies: 2Last Post: 23rd Jan 2008, 22:59 -
How to convert swf to avi ??
By yunakokimama in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2007, 03:20
