Thanks in advance for answering the following question.
Does anyone see anything wrong with this strategy?
I am capturing from vhs-c with an ATI All-in-Wonder 128 Pro in a custom format (MPEG-1, 640x480, 8 m bit/sec). I went with that format figuring that the higher the bit rate and res the better quality the capture (I know vhs-c res stinks anyway, but at lower bit rates I was getting choppy and pixelated video.) My intention is to have a high quality capture that I can convert to VCD or DVD at a later time. Am I missing anything obvious? In other words, am I wasting my time capturing in this format? Or, does anyone see any potential conversion issues. I have a 200GB HD, so space is not an issue. Also, I was having problems capturing directly to MPEG-2 or I would have just done that.
Thanks.
IF you are doing home videos then you may need a TBC ( search for more info ).
Also mpeg-1 was not meant to handle Yx480 since mpeg-1 does not do interlaced materal ( although with that many bits it may not matter ). I think it would be a better stategy to cap to DVD mpeg-2 if retention is your goal.
Just my .02USD
NEWBIE Burn HD DVD
By Wally 2007 in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2011, 21:10 -
Newbie question: cannot view/capture older DV tapes
By sinbarambam in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 9th Jun 2008, 08:48 -
newbie,i have a problem,i burn a dvd on playback i get stutter when panning
By goldenbhoy in forum Newbie / General discussionsReplies: 10Last Post: 28th Apr 2008, 15:00 -
Newbie Question: Can I use Alcohol default settings to burn DVD-5?
By ShadowRider in forum DVD RippingReplies: 1Last Post: 11th Aug 2007, 15:56 -
Capture in segments...help for newbie!!
By wormdog88 in forum Capturing and VCRReplies: 0Last Post: 10th May 2007, 08:37
