What is the best program to use to convert .mpg files to VCD/SVCD format?
Firstly, your question isn't quite right. There is no such thing as a VCD/SVCD file format as such.
VCD/SVCD refer to the whole disc -- the the video on those discs happen to use MPEG-1 and MPEG-2 respectively.
If you want to put an MPEG on VCD or SVCD, you should first ensure that your MPEG has the right specifications. You can't just put any old MPEG onto a S/VCD. Have a look at: https://www.videohelp.com/vcd and https://www.videohelp.com/svcd
Assuming your MPEG is okay, then you will need a S/VCD authoring program to make the VCD for you from the MPEG(s) source files.
I suggest VCDEasy as it gives you the best control over making a VCD (including menus, chapters, etc) but if you have Nero, it can make simple VCDs as well. Just choose the VCD option in the Wizard and follow it.
Regards.Michael Tam
w: Morsels of Evidence -
(S)VCDs are .mpg format.
however, VCD = mpeg1, while SVCD = mpeg2
you need to determine if your .mpg if mpeg1 or mpeg2...once you find out, you can directly burn the .mpg fo (S)VCD w/ nero, drag-and-drop...
there's should be no need to re-encode...especially if you have a lower quality mpeg1, there's no point to re-encode that to mpeg2 because all the bitrate (video information) has already been lost in the encoding of the mpeg1.
i'm thinking the only reason you would re-encode that .mpg is if it's not to standard...i.e. both VCD and SVCD have specific resolution requirements....also, VCD 2.0 has specific standards about bitrate, resolution, etc...so if your .mpg is not to standard, you can burn it as a non-compliant xVCD or xSVCD, or try to re-encode it to standard specs...but you will lose quality in the re-encode process. -
Originally Posted by vitualis"Art is making something out of nothing and selling it." - Frank Zappa
Originally Posted by poopyhead"Art is making something out of nothing and selling it." - Frank Zappa
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 18:28 -
Converting Analog Tapes (from CCTV) to Digital Format (AVI, MPG...etc)
By leungjing in forum Video ConversionReplies: 2Last Post: 7th Sep 2009, 13:22 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
