I am close to buying my first Dvd writer ( a Pioneer DVR-A06 hopefully )how important is my hard drive in regarding a Fat 32 or NTFS partitions I am Currently using Fat 32 after upgrading to Windows Xp recently and how easy is it to convert to NTFS![]()
Results 1 to 9 of 9
FAT32 limits file sizes to max of 4 gigs...so if you're making an .iso image file of a DVD greater than 4 gigs...the .iso file will be truncated at 3.99 gigs...so best bet is to go /w NTFS, like txpharoah said
BAck up your stuff if you're swithcing a drive with data on it
over to the new file format
ONE in a thousand TIMES THE CONVERSION IS NOT GOOD
ITS way BETTER TO FORMAT A RAW DRIVE THAN CONVERT ONE THAT HAS STUFF ON IT -
NTFS without a doubt. It runs faster and has less problems while running. Converting to NTFS with WinXP is a snap. It takes no time at all and you won't loose a bit of data. Good Luck!!!
BUT you will not be able to select the 4kb cluster size if you convert in WIN 2k so do as he says in XP only becauseIt takes no time at all and you won't loose a bit of dataso in 2000 the convesion is a WORKAROUND at BESTIn Windows 2000, CONVERT handled this problem by forcing an NTFS cluster size of 512 bytes, which resulted in reduced performance and increased disk fragmentation. In Windows XP, CONVERT chooses the best cluster size (4K is the ideal).
WHICH is why getting your data off there first and formatting a raw drive is preferable -
NTFS has better support for large file size, obviously video files can be gigantic, so NTFS will be optimal
Looking for free software to partition and backup netbook partition
By jimdagys in forum ComputerReplies: 4Last Post: 30th Nov 2011, 22:20 -
Converting FAT memory stick to NTFS
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2011, 01:47 -
FAT+ troubles with .mkv merged files
By fabpozzi in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Jan 2011, 11:29 -
Security bits in FAT & NTFS?
By G)-(OST in forum ComputerReplies: 9Last Post: 22nd Aug 2009, 15:16 -
FAT to NTFS
By hardy in forum ComputerReplies: 13Last Post: 24th Jun 2009, 16:24
