I just purchased a Sony 510UL. Everything works fine except the compatability of the +r discs to my SA player. The culprit seems to be that the book type is listed as "DVD+R" by DVDInfo. I have an NEC 1100A that burns my +r's as "DVD-ROM" for compatability. So I know these +r's work fine in most of my SA players. The only difference then is the book type between the Sony and the NEC.
On a side note the -r's play fine on the SA players but I would like to know if/why the Sony doesn't change the bitsetting to DVD-ROM like the NEC, to achieve wider compatability.
Is there a known way to change this? Thanks for the patience with a newbie.
Alex,
I believe this requires a FW change to support the utility to change the bit settings. Sony probably did not implement this because they are a core member of the Forum and changing this Bit setting might be seen as going against the DVD-ROM format. You might try some of the utilities on DVDplusrw.com but I doubt that you can change it.
See the link:
http://www.dvdplusrw.org/resources/bitsettings_pc.html
RG -
Thanks for the reply. I did try that bitsetter programs, hoping it might just work, but no luck. I didn't realize that Sony was part of the "DVD Forum". (You sure learn alot at this site!)
Anyway, on a lark, I sent Sony Technical an e-mail. Let's see what they say.
As I said before, the -r's produced by the 510 are playing fine on my home SA players. And the NEC is taking care of my +r's when the need arises. It kinda sucks tho that the Dual-Format is actually limited at the moment.
Once again thanks for the info, and patience, if this is old stuff. -
I also wish my Sony would bitset. I have two DVD players, a cheap one and an older one which won't play +RW without setting the bit. The old one won't play DVDPro -R discs.
Is there an MPEG2 editor that will let me change its audio type?
By Nuke Shower in forum Video ConversionReplies: 6Last Post: 9th Apr 2008, 17:00 -
Can't change book type with Img Burn and Samsung 203N
By Vidikron in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Apr 2008, 03:41 -
Sony RDR HX 510 and DVP NS 305
By SearchQuality in forum MediaReplies: 10Last Post: 16th Nov 2007, 11:41 -
book type management
By MasterThomasMI in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2007, 14:23 -
Pioneer DVR112 book type setting?
By tac7 in forum DVD & Blu-ray WritersReplies: 3Last Post: 26th May 2007, 17:02
