I'm hoping to buy a capture card soon, and I have a question that haven't been answered by several evenings worth of reading the reviews and searching these forums... any help would be very much appreciated.
Most of the reviews rate cards on the ease of setup and the quality of the hardware-compressed video - but I'm only interested in capturing losslessly (HuffYUV). Can anyone tell me which are the best (PAL) cards purely from the point of view of the quality of the uncompressed output? (In terms of colour fidelity, sharpness, etc.) I will mainly be capturing from decent quality VHS.
Thanks!
Mohan
If your talking about the codecs involved, then the hardware doesn't really enter into it, only so far as if it will be able to do say MPEG2 or AVI.
As long as the software your card can use will allow you to use lossless codecs, you should be fine. -
Thanks... that means the only reasons to prefer one card over another would be dropped frames and audio sync. problems?
There are differences because of the hardware. The quality you get from the input is a factor hardware related.
Anyway, the best card for this task IMHO is Vidac VMagic
Alternatives: Some people like ati solutions. I don't like them..
Personally, I'm very happy with my Win TV Primio FM card (typical bt808). I can capture and proccess really easy and with excellent results VHS.
Here is the key: Hardware helps. But the good post proccessing of your captures is what really do the difference!
IMHO always. Others may have a different opinion on this.
Capture Lossless with WinTV-PVR-150
By rudolf016 in forum Capturing and VCRReplies: 50Last Post: 28th Feb 2012, 12:39 -
Recommend a <$100 capture card for analog to lossless AVI codec
By Cheesyii in forum Capturing and VCRReplies: 8Last Post: 27th Dec 2011, 09:49 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
Modern consensus on best sub-$250 lossless AVI-capable analog capture card?
By Mini-Me in forum Capturing and VCRReplies: 31Last Post: 9th Jul 2010, 06:18 -
How to Capture DV on Lossless?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 43Last Post: 27th Aug 2008, 21:10
