Hello,
Recently I edited together 2 captured MPEG2 files using Vegas 4.0. When I try and create output files using MovieFactory 2, I get the following error right at about the time the files would have been edited together (90% or so through processing):
Failed to convert video file
Error: 80041c21
Does anyone know why I'd get that where the files were edited together?
Thanks.
Guest
Are you trying to create an Image file with MF2? Becuase Vegas 4.0 should have already created a single video file for you. Are both of the edited together mpeg2 files of the same bitrate and resolution? Does it play properly in the MF2 preview?
Guest
Well actually, to start with, I was trying to burn it to DVD. But I got that error message, so I tried creating an image file. Same error.
The movie plays flawlessly in MF2's preview window -- even up to and past the edited point.
I think the video was captured in variable bit rate -- does that matter?
Thanks! -
I would suggest that you create a very short video using the built-in encoder - and then try to burn it to DVD.
If that works, then it's likely the Ulead DVD MovieFactory 2 program installation was successful.
It would also suggest something about the encoding parameters in the Sonic software is in need of adjustment.
Jerry Jones
http://www.jonesgroup.net
moviefactory 6 plus problems
By steenuil in forum ComputerReplies: 0Last Post: 3rd Feb 2010, 07:35 -
dvd moviefactory 5
By bigz704 in forum Newbie / General discussionsReplies: 0Last Post: 24th Sep 2009, 15:54 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 01:51 -
DVD MovieFactory 6
By Mike99 in forum Authoring (DVD)Replies: 2Last Post: 24th Nov 2008, 06:14 -
DVD MovieFactory 6 Plus
By ozab in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2007, 17:48
