Results 1 to 14 of 14
  1. and what is triggering this (wrong) response?
    -K
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Are you using Safari 1.0???
    Site feedback in the feedback forum. I'm moving this one.
    Could you explain EXACTLY what happens?
  4. its a Safari bug it appears...thanks tgpo
    -K
  5. This bug just started today though ....
  6. Originally Posted by Baldrick
    Sure. I attempt to post a follow-up in a thread I've posted in; it tells my I have already posted said message.
    Pretty much it.
    -K
  7. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    it's not just Safari, I get this occasionally on Win98 / IE 5.5
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  8. Damn! I was ready to blame 1.0 software and be done with it, lol
    -K
  9. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    I've been having this problem ever since 1.0 came out. Apple knows about it and claims to be working on it. One way to combat it is to use Safair Extender to disable the caching of websites. It should fix the problem.
  10. Originally Posted by housepig
    Also Windows XP Home Edition, IE 6.0
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    It is no bug...it means that you should not double post..:
    Seriously, I don't know what causing it...it has never happend here so I cant do any testings...if it happens could you please post the link where it says "here".
  12. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    According to Micro$oft it's not a bug, it's a crash "Feature"
  13. Glass houses, buddy...glass houses
    Remember tpgo, some Mac Idiot first reported it, and in typical fashion, put it in the wrong forum
    -K
  14. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    -K
    But if I throw stones I won't break the windows.....I don't have that good of an aim
    Ever since I disabled the cache for Sarafi 1.0 I havn't had the problem anymore. You may wanna give it a try to see if it helps you.
