Got a phillips dvd711 and when i play svcd's that are in ntsc format the audio & video are slighlty out of synch, ive tried them on a friends dvd which is a different make and his does the same, but played through the pc they are fine. Anyone any ideas what could be causing this and if their is a solution?
My first thought is that you've got a 23.976fps video source. The video/audio are in sync from start to finish on the PC but off on the TV correct?
Check the frame rate of the VCD, if it's 23.976, use VCDGear to convert the DAT file back to a MPEG, apply the 3:2 pulldown, re-burn it, and see what happens.
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 17:25 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 06:42
