Ok guys, here's the deal, I have an avi file that I'm trying to convert to SVCD. I have encoded dozens of .avi files without any problems but now everything freezes. I am using TMPGEnc Plus 2.513.53.62 and virtualdub 1.5.4 as usual. First, when loading into virtualdub I get the VBR audio stream detected message. I think, no biggie and strip the audio to wav. When I load the video file into TMPGenc, using the wav as audio, it encodes a black screen. I then increase the Direct show priority and now when I try to load the avi, it freezes. When I lower the Direct show priority the avi loads but encodes a black screen. I figure I have some bad frames so I try to find them and virtualdub crashes. When I try to load the video in AviDefreeze it freeze. So now I'm alone with my avi. Please help!
MY STATS
Pentium 4 1.8 ghz
256 DDR Ram
40 GIG HD
WinXP PRO
Results 1 to 19 of 19
Have you tried to run the Video Scan in Virtualdub "MP3 Freeze Version"?
(scroll down this page to find it)
http://www.digital-digest.com/dvd/downloads/virtualdub.html
Also, have you opened the file in GSPOT?
(post details)
You have a black screen using TMPGEnc.....
Are you using 2pass?
(first pass is blank)"Today is only yesterdays tomorrow" -
I tried opening the avi in G-Spot and it crashed. I then tried opening the avi in virtualdub mp3 and I got the error "Invalid Avi File: chunk at 10240 extends outside of parent by 133476004 bytes." I don't think I'm using 2 pass in TMPGENC because this never happened before and I didn't tweak any settings. The avi shows up as a black screen when I go to source position. I even tried CCE and it crashed. The avi plays ok on my pc but I want to play it in my stand alone dvd player.
we need to know what kind of avi it is to help
Since Gspot crashes, please download the windows movie player 6.4..
OOPS..you have it!
Its in the same folder as the useless new WINDOWS MEDIA PLAYER
so go there and launch it..its called media player2.exe
Now drag your avi to it.
Unlike the newer shitty player which is dumbed down, you can get info here
GO FILE>PROPERTIES>and see if you can get any more information about your file here -
I tried to open it in media player 2 and it crashed. The only player that will play it is Divx Player 2.1. Any more suggestions?
If its a DIVX...try to use DIVFIX:
http://divfix.maxeline.com/index.php?target=showdoc&docid=355"Today is only yesterdays tomorrow" -
I just used DivFix and it reported no errors. I'm open to any ideas and suggestions.
Can you put it on the time line in
ULEAD
PREMIERE
VEGAS
Ift'll play in one of these...you could re render it out to a useable state, or maybe do the work you were planning in another program right there in the NLE editor -
proctorGuestOriginally Posted by dcsos
I have an AVI file that I want to make a VCD out of and when I need to split it using "Source Range" in TMPGEnc it just freezes.. now I gather it will cont. working if I just let it sit, but I don't think it need to take so much to move the slider to the middle of the movie and select that as the end (of part 1). So what can I do? I tried going into mplayer2.exe but I don't know what info I can get out of it that you might need?
P.S.
When I try to open in in VirtualDub I get a window msg saying:
"MPEG Import Filter: packet sync error on packet stream (f813747)" -
I'm not sure about Ulead, but whart I did was download NIMO codecs pack and then when I tried to encode the avi in TMPGENC it showed a green blocky screen. Now I am totally confused.
Do you have FFDSHOW ?
http://sourceforge.net/project/showfiles.php?group_id=53761&release_id=95213"Today is only yesterdays tomorrow" -
First, I would like to thank everyone for their help. I looked at the file more closely and noticed in the filename it had four little letters-XVID-*slapping myself in the forhead*. Could this be why its freezing everything? I downloaded the XVID codec but when I encoded it using Main concept MPEG encoder it played back as a choppy green blocky screen. So with this new information does anyone have any suggestions?
The results of FFDshow is a choppy blocky screen while encoding in TMPGENC, but now it's not green, I actually see images although very choppy.
Oh yeah, by the way, Main Concept MPEG Encoder is super fast. I don't know about the quality since I can't see anything but it only took 53 mins to encode a 1hr 48 min movie to VCD. -
Ok everyone, I figured it out! What I did was convert the XVID to Divx using Vdub. Then I encoded it to VCD using TMPGENC. No audio sync problems and most importantly no green patchy blocky encode. I tried the fourcc trick but it didn't work. If anyone is having trouble encoding XVIDS try converting them to DIVX first using VDUB. I followed the tutorial and didn't lose any quality or have any audio problems.
I have another XVID that crashed Vdub when I tried to encode to Divx. What I did was use the fourcc trick, then when I encoded in Vdub it worked! I suggest you try the fourcc trick before trying to encode an XVID, after that encode to Divx and it should work from there.
proctorGuest
What's the "fourcc trick"?
When I open the file in Vdub I get the error mgs:
When I open it in DIVFIX it says it is'nt an AVI file.
I tried opening it in TMPGEnc in the MPEG tools under "File" then under "Muliplex" and I get this info on the file:
MPEG-1 Video 352x288 25fps 1150kbps
MPEG-1 Audio Layer-2 44100Hz 224kbps
Does this mean anything? -
Originally Posted by proctor"Art is making something out of nothing and selling it." - Frank Zappa
proctorGuest
So the AVI ext. is false?
And why is it that I get an error in the middle of the file somewhere? I tried renaming the ext. from AVI to MPG and then opening it in TMPGEnc but it still gets stuck when I move from position 0 to the middle of the file (cuz I want to make two VCDs out of it). The file as it is right now is an AVI file with 714mb.
program freeze
By mulgui in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2009, 21:03 -
mplayer freeze
By ajv in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 16:15 -
Svcd2dvd Freeze's
By gazinc in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 18th Apr 2008, 13:00 -
more dvd freeze problems
By dblake2 in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2008, 11:27 -
pc freeze up
By triggerstep in forum Video ConversionReplies: 5Last Post: 24th Feb 2008, 04:12
