Is they're such a encoder on the market? Preferrably freeware?I find I have to use one for VOB to Mpeg2(one I have doesn't support 720x480,just 480x480)and export to TMPGEnc for video cleaning, and then to an authoring program to create compliant DVD video. I have My DVD and TMPGEnc DVD for that.
I should mention I'm trying to clean up a VERY noisy VHS to DVD-R transfer that a friend did. I'm pretty new at that. Any recommendations for process and encoders would be appreciated.
Well, if you own Virtual Dub MPEG-2 mod, you can load it there, and frameserve to TMPGEnc.
Hello. -
Just to clarify(it's one of those days!
) you mean Virtualdub with an Mpeg 2 plugin? Thanks I'll look into it.
Do not know about it having an MPEG-2 plug in, but here is the About display:
Hello. -
There is an Mpeg 2 plugin in the tools section.
Any more suggestions people?
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 05:44 -
VOB DTS file to VOB AC3
By shanthaprasad in forum AudioReplies: 4Last Post: 25th Sep 2007, 13:34
