Like the subject says, I really want to capture in as high a quality as possible, both audio and video from this web site. There has to be one of you geniuses out there that can come up with something. Please include links to any software that is needed.
thanks in advance.
http://launch.yahoo.com/musicvideos/
Tommy Knocker has given you the best solution for use on one machine..
BUT IF YOU HAVE 2 or more towers, consider that you can do this by
USING THE TV OUT of a Graphics Card..and the audio out of your sound card (you may need a y-connector to hear it at the same time)
Go to YAHOO, launch the music video you want
now make it full screen
and
JACK OUT THE VIDEO and Audio from the first TOWER to the second computer tower's capture card -
1) There is a program that says it will capture steaming video but before I give a link to it I would like to see a comment from the mods on the legality and or forum rules on this topic.
I never tried the program that I am thinking of and have a link to but it claims to capture streaming real media video also. It's not new and is no longer supported by the original developper but some sites still have the prog and someone seems to have updated it.
2) I did something similar to what user dcsos suggests as a test a long time ago but I simply connected my display card's tv-out svideo to the svideo on my capture card and captured the video from that source. For the audio I used the speaker out from my sound card and looped it back to the audio-in of my capture card. I had to allow a bit of extra capture since I had to start the cap first then start the player and then put it full screen but I was able to edit out the extra lead and trailing stuff out of the avi afterwards in vdub. I'm, not saying it's the best but it does work. It works with DVD's played from your rom drive also.
3) I believe a program called Hypercam is a better solution than snaggit since it will capture screen video and audio directly to avi format. Sorry I don't have a link but it should be easy to find.
So what do you think mods? Any thoughts and or suggestions? Should I provide the link to the prog in point 1.There's not much to do but then I can't do much anyway. -
-Remember, I'm looking for the highest quality possible audio/video.
thanks for all the help so far!
Blackmagic Intensity Pro: Can't capture from any VCR source
By mvrx in forum Capturing and VCRReplies: 22Last Post: 31st Dec 2012, 13:42 -
Automatic - Programmed Capture into DV of analog source via Firewire Device
By lasith in forum Capturing and VCRReplies: 5Last Post: 12th Feb 2010, 04:03 -
Video capture & picking sound source
By nilla in forum Newbie / General discussionsReplies: 0Last Post: 22nd Oct 2009, 08:33 -
Multiple DV source Capture card/box help/advice needed please
By OdubruS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Dec 2007, 11:08 -
resolved: Need source for software for capture through ATI VIVO card
By palouse in forum Capturing and VCRReplies: 5Last Post: 7th Jun 2007, 10:56
