I jus got a Dazzle Digital Video Creator II, and i wanted to know how to capture from PC (Movie File) to VCR (VHS TAPE). At a preety decient quality, what do i use need to download?
To go from PC -> VCR you need a TV out. Just plug TV out into VCR and record as normal? Or did you mean to ask how to go from VHS -> PC?
no from PC --> VHS would like to know what programs i need and how to exactly do it correctly, THANKS
""no from PC --> VHS would like to know what programs i need and how to exactly do it correctly""
What Vejita-sama stated !
Just plug TV out of video card into VCR and record as normal
Use windows media player at 'full screen'. This will yield poor results on a low res capture/source.
Reset screen size to 640*480 to achieve the best 'full screen'
I have a Dazzle DVC I and on the back there are composite and S-VHS plugs for output to A/V devices like VCR or a TV (so you can check what the capture would look like when played as VCD). There is a standard option to play an MPEG file and the output on the Dazzle can be recorded. Probably this is the same as on the DVC II. I think you should check your user manual. If you don't have any, try downloading it on the Dazzle website, if available.
when i capture from PC --> VCR, and when i have Windows Media Player at full screen, will it also capture the mouse pointer?
Newbie - need DVDR/VCR combo w/Dig Tuner
By pamelajaye in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2010, 06:25 -
capture from vcr
By bbxrider in forum Capturing and VCRReplies: 27Last Post: 16th Aug 2009, 17:18 -
VCR capture troubleshoot
By Abas-Avara in forum Capturing and VCRReplies: 11Last Post: 16th Aug 2009, 05:26 -
capture video from VCR
By nbdeb59 in forum Capturing and VCRReplies: 2Last Post: 3rd Jul 2009, 00:57 -
Capture from VCR or Camera?
By thomasj in forum Capturing and VCRReplies: 3Last Post: 26th Nov 2008, 15:13
