I am new to capturing video and looking at getting a new VCR. I can't decide if getting a s-video VCR is better than a standard RCA one. Someone mentioned that TBC is the way to go. What exactly is TBC?
Thanks.
Time Base Corrector
https://www.videohelp.com/glossary#Time%20Base%20Corrector
The dataVideo TBC-1000 is regarded as on of the best, within an affordable range.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
In case anyone clicking here wanted to know quickly
TIME BASE CORRECTOR=TBC
does just that..
If there are frames or lines of video missing from an analog tape* recording, this device does the job of ON THE FLY correction of the signal
Most use the tact of PRESEVEING the last good frame or line and replacing the bad signal with a new one that now comes out of the TBC at the exact frame rate (30FPS for NTSC)]
* due to stretching baking or abuse
The best TBC's have a full frame of correction..the cheapest only correct a few lines at a time..(the expensive ones usually have a freeze frame or timed stobe frame option, too!) -
Actually, that would be called Drop Out Compensation --- DOC --- and doesn't normally happen with just a plain old TBC.Originally Posted by dcsosHope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Hey Idiot
I beg to differ..
the original poster probably couldn't care a whit... but the drop out compensator preceeded the TBC in invention..and is in fact a less powerful solution for analog tape defects
Not to say you don't need a DOC or Drop Out Compensator
The first ones were simply a feedback circuit to the capstan (early VIDEO MACHINES were reel to reel before cassetes took over)
So an error detected by the AMPEX DOC in 1955 was fixed by jockeying the TAPES speed in real time so quickly you never saw a dropout.
All VIDETAPE recorders now feature this drop out compensator that now removes problem areas of the frame thru delay line technology and no longer speed adjustment.
ON the other hand the time base corrector (TBC) was invented in the early 70's by CVS video (they won an emmy for it in 1973)
and was a COMPUTER development wherin a LINE of video was actually stored in the thing until a bad line came along, and it was replaced with the version on hold in the box's memeory
The first full frame TBC that could TIME IN A SATTELITE BROADCAST or remote feed from FAR AWAY was twenty thousand dollars by 1977.
Adda Corp and Microtime were early makes of TBC's that could correct anything by saving a frame in memory ..ready to be clocked out of the box at the required frame rate..at a cost that went down to 500 for a full frame in the late 90's
A frame of memory took 5 RACK-UNITS in 1978
Now its on a chip -
We still use old Microtimes at work
the Addas are a distant memory
Mmmmm.... Quad tape
And my point on DOC is that most TBC only machines do not have DOC. As in the TBC-100(0) doesn't fill in any missing info with info from the previous or next line. You just get a gray (or white/black) spot for the missing info.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 20:31 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 12:58 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 09:29
