How much disk space does one need for a 120 minute frame rate XVID to AVI conversion? How much disk space does one need for a 120 minute AVI to VCD mpeg 1 conversion?
My disk space seems insufficient for a frame rate conversion (11.6 Gig free). Let me know if you could give me some ball park figures.
Originally Posted by Robert_Neville
- John "FulciLives" Coleman
P.S.
When I was using the 12GB drive it was a SECOND HDD so I didn't have to worry about the cache size thing since that was on my OTHER HDD but even if you only have a single HDD with 11.6GB free it should be more than enough to convert your Xvid to VCD or SVCD or even an mpeg-2 DVD file. BTW the Xvid is already an AVI type file so why would you want to convert it to AVI using aother codec? That doesn't make much sense!"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Fulci,
Well, VirtualDub told me that my disk space was insufficient when executing an AVI un-compression. I must have done something wrong. Essentially, my objective involves converting a XVID AVI file in a VCD playable on most rudimentary DVD players.
Does one need to convert the XVID to an un-compressed format before re-encode? This question may seem elementary, yet I am familiar with MP3 to Wav to CD.
Could one directly convert from an XVID to mpeg 1 wihtout quality loss?
The original question has me perplex. Why would VirtualDub require more than 11.9 gigs for a conversion process? -
There is no need to make an uncompressed back-up of the XVID
You should be able to open the XVID AVI file directly in TMPGEnc or whatever MPEG-1/MPEG-2 encoder you use.
The reason why you don't have enough space is that you are trying to save the XVID in VirtualDub as an UNCOMPRESSED RGB file. This takes up a HUGE amount of HDD space but it not required to create a MPEG-1 VCD compliant file.
Are you using Vdub for a frame rate conversion? If that's the case, you can save the disk space and eliminate the need for an intermediate (large, uncompressed) file by frameserving directly from Vdub to your encoder. Check the guides for instructions on frameserving."Art is making something out of nothing and selling it." - Frank Zappa
Frame rate conversion help
By Og in forum Video ConversionReplies: 20Last Post: 8th Nov 2011, 09:56 -
Frame Rate Conversion
By roberto188 in forum Video ConversionReplies: 17Last Post: 5th Mar 2011, 10:11 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
By Alexstarfire in forum Video ConversionReplies: 35Last Post: 22nd Aug 2007, 13:34 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
