I'm trying the basic version of Cinema Craft encoder and can't seem to get it to accept avi files. It says it does but I get an error message stating
"can't open ed file". What gives?
download dvd2svcd from www.dvd2svcd.org and try CCE with that . Based on not having any information on what the source, is that would be my only advice. By doing this, you can ensure that things are set up correctly to go to CCE
I suggest reading this
Also an .ecl file is the CCE project file. Try right clicking the big white area n the middle of CCE's main window and when it says "add", then go and import the avi.
Read the guide and a whole lot wil be made clear.
Goodluck,
VCThis is so much fun! -
VC, thanks for the reply. It appears that some of my avi files had a fps that were not acceptable to CCE. When I got home and tried a few other files, they worked but there are some that just don't.
Just for laughs and giggles I tried these in TMPGenc and they were accepted.
It's all good as long as I know my $$$ spent on CCE is working.
Thanks again.
Paul
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 12:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 17:51 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 24th Aug 2010, 00:17 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 17:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 19:05
