    Jul 2003
    Florida
    I have some custome DVD-R's that I bought from a friend, I tried copying one of them to a blank DVD+R but when I put the copy into my home DVD player it says "Disc Error". Now, I can take that same DVD and put it in my Computer DVD player and comes right up and plays no problem. Do I need to copy my Custom DVD-R's to only new blank DVD-R's and not DVD+R's? Or someone mentioned to me that maybe I just need a different media? Right now I am using Phillips DVD+R's and I was told to try Verbatim or some other ones.
    Does anyone know what I did wrong or have any suggestions for me?
    Thanks.
  2. How did you copy it?
    There are all kinds of possibilities here -- you may indeed have bad media, but I wouldn't immediately jump to that conclusion. When you put the DVD you copied into your computer can you see the files there? Are there two folders, VIDEO_TS and AUDIO_TS at the root directory? And are there VOB files in the VIDEO_TS folder?
    One possibility is that you copied the disk wrong -- a DVD needs to be formatted a certain way and if you just "copied" the files over (like burning backup files to a CD) then a standalone player won't play the DVD.
    There isn't any problem with backing up a +R to a -R or vice versa. But we would need more information before we could help you further.
    "Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
  3. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    Sounds like a media problem to me, your DVD player might have problems recognizing DVD+R. As to what media you should try, I use TDK DVD-R and have no problems and have no problem with playback. I use to use Verbatim but read alot of post about the different media codes when being put through DVDInfo. So I checked a few of my own and it was true, and I did not like that because you did not know who was really making them. So I stopped using them.
    GOOD LUCK,
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
  4. Member SLICK RICK's Avatar
    Mar 2003
    One more thing before you go out a buy a new batch of media. The most succesful way that I have found to copy a DVDR to DVDR is to use DVD Decrypter and copy to hard drive and then burn to DVDR using whatever software you like.
    SLICK RICK
  5. Yes, but don't confuse this guy -- the DVDs he got from a friend are most likely not encrypted and therefore DVDDecrypter isn't needed. All he really needs to do is copy the VIDEO_TS and AUDIO_TS folders to his hard drive and then burn them correctly.
    Jul 2003
    Florida
    SlickRick and Mkelly, when I copied it I just opened ROXIO and did COPY DISC. I put in the original and put in the blank and hit copy. I just downloaded that DVDDecrypter program so maybe I will give that a try. I may try the TDK media as well. Any other input would be great.
    Mkelly, yes I could see the VIDEO_TS on the root of the DVD using Windows Explorer. There is no AUDIO_TS but there is sound on the DVD? There are 3 types of files under the VIDEO_TS root, they are:
    .BUP
    .IFO
    .VOB
    Any other input?
    Thanks for the help guys.
  7. Your problem then is how you burned the disks. A DVD is a special case disk, and as a general rule you can't just do a disk copy of it.
    Here's the easy way -- drag that VIDEO_TS folder onto your hard drive. Make another folder, AUDIO_TS (not strictly necessary but it will conform more to the DVD standard -- it will be empty) and then copy both folders using either Nero or Record Now (trust me -- Roxio is a piece of crap that is only wasting space on your hard drive) in DVD mode. If you don't have Nero you can download the 30 day free trial, although I much prefer Record Now. I can almost guarantee you things will then be fine.
    Jul 2003
    Florida
    mkelley, thanks for the valuable info. I will download Nero or Record Now and do what you suggested. For some reason I thought doing a "Disc Copy" would do the trick.........I guess this is how you learn to do things the right way. Since you prefer Record Now, I think I will try that one first.
    Thanks again.
