I am trying to cut a 1+ gig mpeg file with bbmpeg(avi2mpeg2).
I am following "Tenders SVCD Cutting Guide".
I de-multiplexed my meg file with TMPG and then I open bbmpeg.
That is were I have a problem.
When I click on "open vs" in the Inputand Output files tab the program closes.
I get a file explores screen the the bbmpeg program goes away.
Am I doing something wrong?
Brad
Are you using Windows XP?
There is a patch available to allow bbMPEG to work under XP, but I can't remember where its listed. I can e-mail it to you if you like. -
Thanks, you guys solved my problem.
Can I ask a simple question about bbmpeg while Im here?
Why is it that when I split a mpeg file and give the starting seconds and ending seconds and then I tell it to make the file 800mb.,it ends up being a little more than 800 mbs.
The last one I did was 818mbs.
Tanks
Brad
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
