The program worked fine and plays on power dvd but when i take it to
my stand alone i get the error please check tv settings. It plays everything
esle vcd/svcd/dvd-r any insight would be helpful. I am using the + version.![]()
Results 1 to 15 of 15
AnonymousGuest
are you trying to play a pal dvdr created with dvd2svcdmpg+ on ntsc equipment ?
i belive this is more of a problem with your equipment and not dvd2svcdmpg+....
just my thoughts -
AnonymousGuest
How do i find out what it is creating (pal or ntsc)
and is there a way to change on the program
i have looked and cant find anything
thanks for your help urie
check the settings of the origional mpg 352x388 25 fps is PAL, 352x240 29,97 or 23,976 is NTSC. You can use bsplayer to see the information.
AnonymousGuest
the only settings i get are 480x576 @25
i have tried all the mpegs and the bin files and
get same results
i am at a loss here..........will work for tech support!
So you got a good PAL dvd but you need to check if you player can play svcd & dvd-r/dvd+r.
And if your tv can handle the PAL signal or if the dvd-player can convert the PAL signal to NTSC.
Yf -
AnonymousGuest
YF
your were right my tv only plays ntsc and my dvd player can not change it
over to that. I have looked on google for converter there are a few ..
can you give me the one you recomend?
Thanks again
i know they are there but which i wouldn't know cause my dvd and tv play both pal and ntsc
AnonymousGuest
lucky you!
Thanks for all your help
im one less step away from throwing my PC out the window
We should see if ChrissyBoy could look at implementing a pal to ntsc, ntsc pal conversion in SVCD2DVDMPG, then this would be one kick ass tool, not that it isnt already :P
autorf -
all the latest tv's and dvd-players here play both PAL and NTSC so i don't need it..
AnonymousGuest
autorf has a good idea ...were not all as lucky as you mr my tv plays it
all. j/k
AnonymousGuest
I have the same problem. The mpeg is PAL but I need to convert it to NTSC. What do you guys suggest? All the help is greatly appreciated.
I've only converted from ntsc film to pal but there are some guides in the guide section about converting and some threats about it in the forum i'll give you a starting place.
https://www.videohelp.com/forum/viewtopic.php?t=161402
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Please check my settings before I pull the trigger !!!
By FatBoy123 in forum Newbie / General discussionsReplies: 18Last Post: 6th Jun 2010, 21:56 -
DV Quality - Check This Out
By J. Baker in forum Newbie / General discussionsReplies: 6Last Post: 16th Jan 2009, 19:13 -
nokia 6230i check connection settings
By Mr anderson in forum Off topicReplies: 0Last Post: 23rd Nov 2007, 04:13 -
Check this out!
By mikee55 in forum Off topicReplies: 6Last Post: 18th May 2007, 11:17
