When I try to make a duplicate copy of an existing (s)vcd disc I always end up with a less than perfect copy. At the very beginning of the new disc there will be some pixilating that wasn't there before and it often will freeze up on some older DVD players and even PowerDVD on the computer. I have used CDRWin, CloneCD, and Nero with the same results when creating an image and then burning a new disc. Also, when I use ISOBuster to rip the mpegs off the disc they have the same problems as the ripped images when tested with PowerDVD. The only way I have been able to work around this problem is to use Windows explorer to copy the dat/mpg files from the CD to the HDD then reassemble the (s)vcd with VCDEasy for burning. This method produces clean copies of the mpg files but is a lot more trouble than just copying the disc. Has anybody else experienced this problem and if so is there a solution to it.
TIA, Harry
I've used CDRWIN to make bin/cue's and both burnatonce and VCDEasy to burn them to a new CD, worked fine.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
What is the latest best freeware for making copies of my own DVDs?
By govtdog in forum DVD RippingReplies: 5Last Post: 22nd Jan 2012, 08:50 -
DVD burning problems with new discs
By Lensmeister in forum Authoring (DVD)Replies: 10Last Post: 9th Jan 2011, 10:19 -
Problems with Philips +R DL discs
By carlmart in forum MediaReplies: 17Last Post: 29th Sep 2010, 07:24 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 15:56 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03
