I've been reading this forum for about a year,and usually find the answers to my questions. But I need help with this one.
I started converting my home videos with a wintv go card. The captured files were to dark so I used virtual dub to brighten as I captured and it worked great. I figured it was a flaw in the wintv card and dealt with it.
Now I have bought a dv camera and I have the same problem with the download video,even though I am useing a firewire card. Virtual dub does not work with my dv camera (to my knowledge). So I need a capture program that will let me brighten while downloading my video. Or some other suggestion to help me correct my problem. I have tried different capturing programs and they all do the same thing. I have tried brightening the movie while editing but that is a frame by frame thing and very time consuming. Thanks to anyone who can help.
system
xp2200
512 meg ram
80 gig 8meg cache W/D
ATI 8500 video card
Windows XP Pro
Panasonic DV 102 camcorder
if you are going to put this on vcd or dvd (or any format to be played on a tv versus a computer monitor), author a small test segment first before you alter any brightness settings.
computer monitors commonly display the video a lot darker than your tv will, so check and make sure - it might be fine, even if it looks dark on the computer.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Thanks for the suggestions. Housepig, I think I tried playing a svd on the tv and it was dark. But I'll try a test to make sure,as it has been awhile back.
Darker label with Lightscribe
By omega_weapon in forum MediaReplies: 9Last Post: 26th Apr 2011, 19:53 -
Travelling darker columns on VHS
By Cole in forum RestorationReplies: 2Last Post: 15th Mar 2009, 15:09 -
Why is this? one normal, one yellowish/darker while playing at the same tim
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2009, 16:30 -
WinDVD8 unlike 4 gives darker picture
By DBenz in forum Software PlayingReplies: 0Last Post: 18th Jan 2008, 18:31 -
Flash videos look darker after encoding
By DVinci in forum Video ConversionReplies: 2Last Post: 30th Jun 2007, 01:35
