Hui Guys (girls), i´m a total newbie........ i just ripped my first movie (Galaxy Quest) from a DvD.... And i forgott to split it (so i can burn). The File is on 865 105Kb. So know i must split it!???????? Wich program should i use?
And must i know VB or some like that to do menus (DvD menus)????
Thanx ver very much for an answer!!!!!
There are a number of programs you can use to cut. TMPGenc would probably be the easiest to use. Just click on the edit link to your left and read the cutting guides.
You dont really need to know anything special to create menu's. vcdimager does use xml scripts to create menu's but there are gui's available which give you a front end so you can point and click rather than typing everything out. There are lots of other programs that can author menu's also. click on the AUTHOR link and read there.
Converting LIT to PDF Adobe (Ebook)
By Teac23 in forum ComputerReplies: 0Last Post: 30th Mar 2010, 12:49 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
power LED is not lit, computer's working
By cL0N31 in forum ComputerReplies: 9Last Post: 3rd Sep 2008, 14:16 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 01:00 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 23:35
