Download and read more http://www.cdrbase.com/showthread.php?threadid=30783Code:
History:
a - added
f - fixed
r - removed
c - changed
n - note
V1.3.2 Lazy as hell...
a - 'One Click Solution" to Tools, this requires at least DVDDecrypter 3.1.5.0
and at least InstantCopy 7.0.3.140 to be installed. This nifty little
Feature supplies you with a virtual DeCSS for InstantCopy. Basicly its
just a BatchOperator wich first calls DVDDecrypter to get the DVD to your
harddisk and after DVDDecrypter has finished passes the newly ripped Files
directly into InstantCopy, where you can proceed as usual.
n - One Click Solution lists only DVD-Roms only on WinXP & Win2K on all other
Windows versions all CD/DVD-Roms are listed in the Sourceselection, this is
because there is no reliable way to detect DVDRoms under all versions of
windows without involving ASPI, wich thanks to MicroSoft cant be directly
called from Visual Basic! So this was the most practical solution without
the need for any external wrappers/dependencies. And hey, i think youre
clever enough to pick the right drive all by yourself, arent you ?
a - option to burn with DVDDecrypter after conversion to One Click Solution
(this is only useful if you are sure that the resulting pdi set satisfies
your expectations and will have a size equal or less 4.37GB. Otherwise
leave it turned off!)
n - Burning with DVD Decrypter might not be very reliable, cause automation for
burning is not officialy supported. But worst thing that can happen is that
either the burning doesnt start or DVD Decrypter does not exit when
finished. So no need to worry! Give it a shot! Feedback highly welcome!
n - For those who care: NO! There are no SendKeys Commands used in the
automation Process! It's real windows messaging!
a - After Batch Operations to IC Batch Control, this enables you to ShutDown
Windows after the Batch is completed (Greetz RB). There are two shutdown
options, the normal and the forced, if you select force any open
application is forced to exit, though this could result in lost of unsaved
data. so be careful with this option
a - an option to start InstantCopy Hidden Settings Editor displaying the newest
available settings first. E.g. if you are using InstantCopy 7.0.3.140, the
settings that were added for this version will be shown at startup
a - Wipe DiscData to the 'IC Settings' menu. This is useful if you reencode a
DVD with changed settings that you had already done before. It ensures all
analasys is redone in InstantCopy. Use this feature with caution all saved
data in the DiscDataPath is wiped, including the 'F6' saved settings.
a - Tips & Tricks System to provide you with some quick hints, this is optional
and can be turned on/off either in the Tips and Tricks window or in the
options. Tips & Tricks are also accessable from the '?' menu
a - Versionverification for DVDDecrypter to precisely enable/disable supported
functions in InstantCopy Hidden Settings Editor
a - History Viewer for InstantCopy Hidden Settings Editors History, its
available from the '?' menu, but only if the History.txt File is in the
same directory as InstantCopy Hidden Settings Editor. This was basicly
added to have a correctly formated view of the History.txt at hand.
a - Drive Info Retrival to One Click Solution (Requires Windows Management
Instrumentation, included in WinME, Win2K & WinXP, can be installed on
other Windows as well, to be Installed! Feature disables itself when WMI
is not present on the Machine!)
a - a very small SystemInfo to About, just toyed around. Had the Infos anyway.
c - Labeling of current InstantCopy Version from (Your Version is : x.x.x.xxx)
to (Your IC is : x.x.x.xxx) to prevent misunderstanding with the context of
the current Settings displayed before it
f - IC Batch Control now changes to automatic resize properly when you are
using custom IC Profiles. This didnt work before. (reported by RB)
f - the Splashscreen preventend access to any MessageBox that could come up
on program start
Can you let me know where to get it without having a cdrbase.com subscription?
As usual Thank you to Mr. Bass
http://www.mrbass.org/instantcopy/InstantCopySettings.zip
Copy encoding settings from the video?
By Charmer in forum Video Streaming DownloadingReplies: 1Last Post: 14th Apr 2010, 09:59 -
Need confirmation of this SUPER settings to copy stream from FLV to AVI
By ohboy888 in forum Video ConversionReplies: 2Last Post: 20th Feb 2009, 04:59 -
Copy font settings to a different sub?
By andy_19 in forum SubtitleReplies: 0Last Post: 15th Jan 2009, 12:28 -
How to copy/convert hidden DVD with only "Track01.cda" in dir
By vincehal in forum Newbie / General discussionsReplies: 9Last Post: 8th Nov 2007, 06:21 -
File and Transfer Settings Wizard Problem. Can't copy several files
By presto in forum ComputerReplies: 7Last Post: 24th Oct 2007, 08:19
