Is this a new limitation? Do I have to get the Pro version to encode higher than that?
If the profile is set to Profile 1: Handheld, then yes, the max bitrate will be 128kbps. Set it one of the last two, or better yet, uncheck "Choose your profile" box. on the Profile tab.
This applies to the pro version (and the others if they also have a "Profiles" tab).
K
VDM Won't Encode to MP3
By adalect in forum Newbie / General discussionsReplies: 41Last Post: 24th Apr 2010, 00:52 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 21:33 -
virtualdub won't encode anything
By johnr283 in forum EditingReplies: 5Last Post: 17th Sep 2009, 20:33 -
FFMPEGX won't encode!
By Kalasin in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2009, 11:02
