i have read in a help section on the site that it is not a good move to convert the audio to MPEG2 for quality reasons?
It said that the audio should be AC3 or PCM?
Does this sound right?
Obviously when your encoding its easy to load up your file and just convert it all together to MPEG2 (or is it MPEG3 for audio or something? excuse my lack of knowledge!!)
But is there a benefit to stripping the audio away from the video first?
It depends what you're making. DVD uses AC3 or PCM, (S)VCD uses MP2.
TMPGEnc (if that's what you're referring to) is not a great audio encoder but it does let you use external encoders such as Lame and Toolame. Yes, many people recommend extracting a wav file and using that as the audio source for the encoder."Art is making something out of nothing and selling it." - Frank Zappa -
I assume you're talking about making a DVD (not a VCD or SVCD, which must have mpeg audio.)
For DVD made for NTSC (US and Japan) AC3 and PCM are part of the DVD player standards. However many NTSC DVD players will play mpeg audio (mpeg audio is standard for PAL players). It is a standards issue, not a quality issue. Mpeg audio is just as good as AC3. Both are good compressed formats. But if you want maximum compatibility on NTSC players you should use AC3. PCM (actually LPCM) is an uncompressed format and takes up a lot of room on a disc and for that reason should generally be avoided in favor of the compressed formats, AC3 and mpeg audio.
Most of the high-end DVD authoring programs require that the the video and audio files be entered as separate files. But many simpler DVD authoring programs take "muxed" files (one with both video and audio). And many simple DVD authoring programs will not accept AC3 audio.
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 08:17 -
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 18:28 -
Convert MKV with ACC audio to AC3 audio for PS3 playback
By wolvie77 in forum Video ConversionReplies: 4Last Post: 25th May 2010, 10:13 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 21:52
