im going to format one of my harddrives so i can use it as a capture drive. i was wondering what allocation unit size would be best for capturing. does it matter? im going to format to NTFS. i would think that the allocation unit size should be bigger so the hardrive doesnt need to change units as often... i mean im only going to store two or three files on there at a time at the most because they are going to be huge files. if anyone could tell me what i should use i would really appreciate it.
also, i was wondering if having my secondary harddrive on the same ide cable as my master would cause dropped frames.
thanks
Results 1 to 10 of 10
The bigger the allocation unit, the faster the drive. BUT, it wastes more space.
so your saying if i want to use it as a capture drive it is better to have bigger allocation units?
Under XP you can only get access to the larger allocation sizes though the command line format command.
For a capture drive use one of the largest options you can get, but don't forget to de-frag or reformat on occasion to keep the transfer rate up. -
Sound advice. I use to think defrag was overrated. After weeks of creating and deleting files, I started droppping frames. Lesson learned.Originally Posted by snowmoon
in XP without using command line the biggest i can get is 4 kb. can you tell me what command i would need to use to format it to NTFS with a bigger allocation size or give me a web site that will tell me how to do it?
format /?
will give you a help page with all the information needed to hand yourself
Hi. xsbs52x
Please Check This. Think On This. I think this is serious issue.
https://www.videohelp.com/forum/viewtopic.php?t=167085
Just Think More or ask if please find right answer tell to microsoft and me.
Regards
Apurv Gupta.JUST EDIT & PLAY.................apnait.com
Capturing with VirtualDub - File size 400GB and only 2 hours from old rec
By Diegovh1 in forum Capturing and VCRReplies: 15Last Post: 28th Jan 2012, 07:40 -
Lens unit required
By rhishik in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 23rd Jun 2011, 11:33 -
What is this time unit?
By Charmer in forum Software PlayingReplies: 13Last Post: 8th Aug 2009, 08:52 -
MKVtoolnix - mkvinfoGUI allocation
By deejay.2001 in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2008, 14:15 -
DVD File Allocation Failed
By Emeraldas in forum Newbie / General discussionsReplies: 8Last Post: 22nd Sep 2007, 09:26
