Hi,
I used SmartRipper and DVDFab to back up a movie. DVDFab created two folders, one per disk, each with a Video_TS and Audio_TS folder. My question is : before burning and risking making coasters, can I play these on my PC to check out whether the menus work, the movie plays and the special features are available. I have PowerDVD and WMP, but can't figure out how to access the features using these viewers. I also have Daemon Tools and it seems to me that I should be able to use that like a DVD player, but again, cannot figure out how.
Any help appreciated,
Morloc
from PowerDVD (at least version 4 and up) there is an option to play dvd files from hard drive.
there's an icon that looks like a disc drive, toward the lower right on the control panel. click it.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
It might be easier to just click on the VIDEO_TS.IFO file for the movie you want to check. That will start the playback in your default player.
LTA -
Housepig:
I only have ver. 3.0. It does have a file function, but I don't know which file to load into the playlist to get the movie to play from the menu screen.
Triple_Helix:
Clicking on the VIDEO_TS.IFO file just opens it in Notepad. Loading it into the PowerDVD playlist doesn't do anything either. Did you mean a different file?
Thanks for trying to help me.
Morloc
Copy/Play HDDVD's from your hard drive
By joepic in forum Blu-ray RippingReplies: 20Last Post: 31st Jan 2012, 04:31 -
How to play HD Video from Hard Drive to Bluray
By jbitakis in forum Authoring (Blu-ray)Replies: 51Last Post: 14th Nov 2011, 15:43 -
What video formats my videos on hard drive should be so my TV would play it
By Panasonic10 in forum Video ConversionReplies: 3Last Post: 9th Dec 2010, 19:25 -
entire movie does not rip to hard drive?
By carlos28355 in forum DVD RippingReplies: 2Last Post: 20th Jun 2009, 05:58
