Hello.
I've just bought AGP Gigabyte ATI 9200Pro 128MB and downloaded MMC 8.5, and newest driver from ATI website. After installation, I cannot capture using ATI MMC 8.5 tool, please help, thanks.
Hello.
Thank you very much, I've just downloaded MMC 8.1 and it worked well. It's the first time I used AGP with VIVO, could you tell me what's Mjpeg codec better : Morgan 3.09, PicMjpeg 2.01 or Mainconcept ? -
Hello !
I had the same expirience with MMC 8.5 and after changing in 7.7. everything was OK.
The best results I got with PicVideo MJPEG codec (a bit faster MPEG2 conversion than others).
Regards -
Hello Tahomir.
Thanks for reply, you're right. Firts, I tryed to capture directly to DivX by codec 5.05, but my CPU is slow 1600+, and there are so many frames was dropped. And then I captured from digital satellite with 3 Mjpeg codec above, and then converted to VCD. In my opinion : Pic Mjpeg v2 is the best, it used about 25% power of CPU, and the quality is excellent.
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 11:13 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
