We have now a build of the dvdmp processing engine that has runtime logging to help locate problems with the conversion process.
If for some odd reason you are having problems still with forty-two leaving you with nothing, and would like to help us definatively find out why, contact us later today about running this build.
It isn't inherently slower or anything like that, but it is a "fork" build and has not yet been tested heavily enough to make it into forty-two "proper" so we aren't releasing a new version for the general populace yet.
If v1.6 is working fine for you, and you'd like to help out as well, you are more than welcome to
Not that this is an NTSC engine. There is no PAL build, sorry.
Thanks,
-K
I would like to try your test build if you need more testers. Let me know how I can download it and I'll give it a go.
I'm currently trying another directory structure variation. I'll post the results. -
You can download the 'Skeeter build here:
http://homepage.mac.com/chris.long/Skeeter.dmg
-K -
I have rerun my DVD -> DVD conversion and did not get a log file in my home directory. Is there something I should check or do to get this to happen?
email me immediately! do not re-run, do not pass go, do not restart or log out!!
-K -
New Skeeter build is ready
http://homepage.mac.com/chris.long/Skeeter2.dmg -
thanks to everyone who wrote in. the problem has been found and fixed. New engines for NTSC and PAL will be in the next release of forty-two.
Need to supply "File Type" and "Mime Type" info for MKV file
By oneking in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2012, 04:31 -
HCenc 2nd pass, what to do about: "*** INFO, adjusting average bitrate..."?
By jclampy in forum Newbie / General discussionsReplies: 14Last Post: 5th Jan 2012, 15:30 -
DeVeDe 3.16.9 build 2 Mencoder "bug" error under XP64
By mail2tom in forum Video ConversionReplies: 1Last Post: 19th Aug 2010, 20:35 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
Non-gaming "tight purse strings" build Opinions?
By louv68 in forum ComputerReplies: 11Last Post: 16th May 2007, 13:04
