The big one.
Results 31 to 60 of 61
the one that has the extension .isoOriginally Posted by Beautiful AloneHis name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
FAT32 hdd???
the fact that one file is exactly 3.99 GB, which is the limit that FAT32 allows files to be, leads me to believe that dvddecryptor just spanned the iso over 2 files because the original DVD is >4 gigs. -
Ok, BA, I think for some reason you got BIN/CUE output. In this case, you can load either the CUE or the BIN file into DAEMON TOOLS, and it will work either way. Just, if you plan to use the CUE file, keep it in the same folder as the BIN
nono, it's not BIN/CUE.
here are the 2 files.
Movie_16X9 <--3.9 gig
Movie_16X9.MDS <--4.22 kb
when i highlight the Movie_16X9 file the details on the lower left box saids..Easy CD creator image file -
Rename Movie_16X9 to Movie_16X9.iso then choose mode>ISO> Write, then find your .iso that you renamed/added .iso to. Then choose your DVD burner and then click on the HD to DVD icon. The burn process will begin.
Now, for God's sake girl, go burn the DVD and let us know how it turned out!!!
you have to have the file extension visible. you don't thats why its not named *.iso. but having Easy CD creator image file as the properties for the file means it most likely is the iso.
I think this sums it up nicely:
With a one click solution you are making a sacrifice of quality for time, but under some curcumstances the difference is not noticeable.
However if you don't mind if it takes some time you can use a method that involves CCE, done properly you will not notice the difference. -
if you don't mind starting over
rip the movie in backup mode with smartripper
then burn the VIDEO_TS folder with your dvd burning program
beginners should never use .iso mode
as it is too complicated
and you probably won't burn it right with easy cd creator -
well..i've already burned the bigger file which is the 3.99 gig to DVD-RW way before i asked the question about why the extension is not .ISO. It worked fabulously!! but just courious on why the extension is not .ISO, that's all.
Yup! just got a new DVD burner not too long ago. -
Originally Posted by funkguy4
so..you too have 2 file? does the bigger one have extension .ISO? -
when u right clicked the file and selected properties
it didn't say .iso file? -
you didn't read my post, did you Beautiful?
Yes. just double checking.Originally Posted by Conquest10
and what do you mean by have the file extension visible? -
DVDdecrypter also burns iso files...no need to use another program. Beginers should certainly rip and burn in iso mode with DVDdecrypter. One program, one format...in/out. It doesn't get any easier than that. That is as long as the original is a DVD5. DVDdecrypter tells you the size of the files so you can see right away if it is a DVD5. If it is not then you can generally still get the whole movie without re-encoding by simply ripping the movie only. That gets a little harder, but there are a ton of guides and easy one step programs that will do it all for you. DVDshrink, DVD2ONE ect...
Beautiful Alone Wrote:
Tell me what operating system you are using and then I''ll tell ya how to make your extentions visible.and what do you mean by have the file extension visible? -
BINGOOriginally Posted by Mordant
You can't beat using DVD DECRYPTER and DVD DECRYPTER ONLY for single layer DVD discs.
With dual layer DVD discs you have several options:
1.) Split over 2 DVD-R/DVD+R discs using a program such as DVDFab or DVDXCopy
2.) Use a transcoder program such as DVD2ONE (my fav of the transcoders) or DVDShrink or IC 7. Usually it is best to just do the MOVIE only and cut out the extras. You can also leave out any subtitle and/or audio tracks you don't need or want.
3.) If the transcoder does not give acceptable quality and you don't want to use step 1 then you need to re-encode using something like CCE or TMPGEnc or MainConcepts MPEG2 encoder etc.
Step 1 gives 100% quality of the original but it takes 2 DVD discs and some movies seem not to work too well (or need a lot of work by YOU to work correctly). Step 2 usually works well but sometimes if the "compression" is TOO much then the quality is degraded to a point of being noticeable and therefore annoying. Step 3 will work VERY well and give better quality generally then step 2 but can take a LONG time plus you can pretty much forget about subtitles (unless you burn them into the image) and multiple audio tracks are out too unless you learn to use something like Maestro (pain-in-the ass and expensive) or use the CCE method as described on the doom9 website. The CCE method is again mostly a pain-in-the ass process as well (at least last time I looked at it) but I've heard it is now MOSTLY automated by several front end programs but I think you need the full CCE SP version and that program is either EXPENSIVE AS HELL or ILLEGAL because I highly doubt most users of CCE SP on this website paid $1,000 plus for it.
Anyways, look at the guides here and on the doom9 website. Everything you need to know (for MOST situations) are there for you!
The BIG file is the real IMAGE or ISO file. The MDS file is simply something DVD DECRYPTER makes when RIPPING in ISO READ MODE. It it basically pointless. After RIPPING with DVD DECRYPTER in ISO READ MODE put it in ISO WRITE MODE then you can SELECT either of the two files as your source file (it really doesn't matter which) and then DVD DECRYPTER will BURN it for you. The MDS file simply points to the ISO IMAGE file which is why it doesn't matter which file you select when BURNING with DVD DECRYPTER.Originally Posted by Beautiful Alone
John is right about decrypter. Its the easy way to rip and burn.
OK, now to enable your system to display your file extentions. Go start> Settings> Control Panel> switch to classic view> Double Click "Folder Options". Go to the "view" tab. Scroll down to"Hide Extentions For Know File Types" and uncheck that box. Make sure to click "apply" before you close out of that!!!
Now your file extentions will always be shown.
Beautiful, lemme know if you got it.
Also, did you burn a DVD yet? -
Its very simple to do what you want.
If dvd is singler layer (DVD-5) Just burn using a smart ripper or deddecrypter. No quality loss whatsoever and your backup is the EXACT same as the original.
If dvd is double layered (DVD-9) Although this can be done with the same prgrams, i recommend using a program like dvd x copy to make your life easier, only when you want to backup a full dvd-9 with no quality loss. You can split the dvd onto 2 dvd-r's and basically have an identical copy of the dvd only split onto 2 discs.
So the answer to your question is, yes. You can retain dvd quality on a backup. -
Originally Posted by cplevel42
cool, it worked. thanks.
Did you read my post above? -
Beautiful Wrote:
Oops, sorry! OK cool.Did you read my post above?
If you need ripping and burning dual layered DVDs and using DVD2one, let me know. -
Hm..after changing the hide Extentions For Know File Types i've now have problems with other files. changed it back to normal now. ow well..that's all right, as long as the files work.
Already achieve the goal of ripping the dual layer DVD's. Thanks. -
doing that should not have done anything to your files except show their extensions.Originally Posted by Beautiful AloneHis name was MackemX
Ever since i've enable it , i've have problems renameing files. This is what the message saids..
If you change a file name extension, the file may became unusable.
Are you sure you want to change it? -
because, when you name a file, you're not supposed to erase or change the extension.
@ beautiful - For example; if you wanna change "movie.avi" to bladerunner then change it to bladerunner.avi. Keep the .avi or else your system will not know what kind of file it is.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
