Would appreciate any advice. For some time have used Nero Ahead to convert/burn to internal dvd burner. No problem playing disc on 2 separate dvd players when I use TDK or Memeorex blanks. Recently I installed and started using EZ Cd Creator 6.0's DVD Builder. Neat prog to use but none of burned discs play in either of the standalones, using same brand blanks. They will, however, playback on the pc with Power DVD player and also one other pc player. I checked all configurations but nothing seems to work.Anyone else have this problem? Also, apparently(?) EZ conflicts with Nero as Nero is now unable to "convert to mpeg2" to burn as dvd. B4 I uninstall Easy and reinstall Nero, I thought I would see if there is something I'm missing here. Thank you for any assistance.
I bet EZ CD Creator is not closing or finalizing the DVDR disc. that's why I removed the stupid program from my computer. I use RecordNow Max for most of my DVDR burning and have done over 300 burns with zero coasters.
problem with Subtitle Creator
By heof in forum SubtitleReplies: 12Last Post: 17th Jul 2010, 01:14 -
Problem with subtitle creator 2.2
By ashkan_vpm2 in forum SubtitleReplies: 0Last Post: 1st May 2010, 17:43 -
Quick AVI Creator problem
By CSULB71 in forum DVD RippingReplies: 14Last Post: 12th Jun 2008, 16:01 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Problem with Roxio Media Creator 9 and slideshow
By ingeborgdot in forum Authoring (DVD)Replies: 12Last Post: 30th May 2007, 11:58
