i need to know which is better ntfs or fat 32 for capturing i currently run win98, win2000, and winxp pro i have two harddrives with the first setup running 4 partitions all setup up as fat32 and it is 80 gigs the second hard drive is 60 gigs and is setup for ntfs and a capture only drive i have some programs that i run that i know will not run in ntfs so my question is should i reformat and make win2000 ntfs and capture to the other ntfs drive or should i leave it as is i must say everything was working fine until i started installing different dvd players now my video card ati 7500 all in wonder will not play mpeg files neither will wmp i can only play mpeg in windvd4 any help is appreciated
thanx![]()
What we have here is failure to communicate!!
NTSF is the better file system in the OS's that support it for capturing.
Best software to re-format NTFS 2TB HDD to FAT32?
By jbitakis in forum ComputerReplies: 26Last Post: 29th Dec 2012, 17:59 -
Converting External HD's from NTFS to Fat32
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 10Last Post: 30th Oct 2010, 14:04 -
External HDD: FAT32 vs NTFS?
By videobread in forum ComputerReplies: 12Last Post: 28th Jul 2008, 17:09 -
For backup, NTFS or FAT32?
By coody in forum DVD RippingReplies: 16Last Post: 1st Oct 2007, 10:30 -
HDD problem NTFS vs FAT32
By edsmith77 in forum ComputerReplies: 4Last Post: 21st May 2007, 12:17
