  1. I am considering buying an iMac which has a dvd burder. however it only burns to dvd-r.
    i was wondering how compatible dvd-r is with the majority of the dvd palyers out there? is dvd-rw more compatible?
    thanks!
    robert
    May 2001
    The DVD-R format has been out longer, so most set top players will play them. Less so for the DVD-RW format. Check the DVD PLAYERS section on the left side of this page to see which players play which format.
  3. read about formats: https://www.videohelp.com/dvd
    DVD-R/W was the first DVD recording format released that was compatible with standalone DVD Players.
    DVD-R is a non-rewriteable format and it is compatible with about 90% of all DVD Players and most DVD-ROMs.
    before you buy a standalone dvd player, first make sure it can read DVD-Rs: https://www.videohelp.com/dvdplayers
  4. thanks for the info.
    - robert
